Saltar al contenido principal
Backpack Strap Buckle Replacement
Qué necesitas
  1. Backpack Strap Buckle Replacement, Strap Buckle: paso 1, imagen 1 de 2 Backpack Strap Buckle Replacement, Strap Buckle: paso 1, imagen 2 de 2
    • Use a seam ripper to rip out the thread.
    • The thread to be cut is the one that attaches the buckle to the strap. It's usually sewn to form an X on it.
  2. Backpack Strap Buckle Replacement: paso 2, imagen 1 de 3 Backpack Strap Buckle Replacement: paso 2, imagen 2 de 3 Backpack Strap Buckle Replacement: paso 2, imagen 3 de 3
    • Pick up the strap buckle that was attached to the strap.
    • Take out the material from the old buckle.
  3. Backpack Strap Buckle Replacement: paso 3, imagen 1 de 3 Backpack Strap Buckle Replacement: paso 3, imagen 2 de 3 Backpack Strap Buckle Replacement: paso 3, imagen 3 de 3
    • Place the material into the new buckle.
    • Look for the original spot which it was originally sewn and place it there.
  4. Backpack Strap Buckle Replacement: paso 4, imagen 1 de 3 Backpack Strap Buckle Replacement: paso 4, imagen 2 de 3 Backpack Strap Buckle Replacement: paso 4, imagen 3 de 3
    • Use a needle and thread to sew the material linking strap and buckle to the bag.
    • Using a sewing machine if available would make this easier.
    • Sew along the "X" outline on material attached to the buckle.
  5. Backpack Strap Buckle Replacement: paso 5, imagen 1 de 3 Backpack Strap Buckle Replacement: paso 5, imagen 2 de 3 Backpack Strap Buckle Replacement: paso 5, imagen 3 de 3
    • Finally place the strap length adjuster into the buckle.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 40
Ultimos 30 días: 162
Todo El Tiempo: 27,572
