Saltar al contenido principal
Introducción
Use this guide to replace a broken phone connector on your Backbone One.
Partes
No se especificaron partes.
  1. Backbone One Phone Connector Replacement, Remove the screws: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Phone Connector Replacement, Rotate the upper part: paso 2, imagen 1 de 3 Backbone One Phone Connector Replacement, Rotate the upper part: paso 2, imagen 2 de 3 Backbone One Phone Connector Replacement, Rotate the upper part: paso 2, imagen 3 de 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Phone Connector Replacement, Remove the screws: paso 3, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
  4. Backbone One Phone Connector Replacement, Unthread the phone connector: paso 4, imagen 1 de 3 Backbone One Phone Connector Replacement, Unthread the phone connector: paso 4, imagen 2 de 3 Backbone One Phone Connector Replacement, Unthread the phone connector: paso 4, imagen 3 de 3
    • Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
  5. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: paso 5, imagen 1 de 2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: paso 5, imagen 2 de 2
    • Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
  6. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: paso 6, imagen 1 de 2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: paso 6, imagen 2 de 2
    • Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
  7. Backbone One Phone Connector Replacement, Remove the phone connector cable: paso 7, imagen 1 de 1
    • Remove the phone connector cable.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Miembro Desde 18/12/19
33,294 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
144 Miembros
15,541 Guías creadas
3 comentarios
Where can i buy a new part
reye_s - Contestar
Unfortunately we haven't found any replacement parts yet. If you find a website that offers replacement parts feel free to share your experience with us.
Adriana Zwink -
Where can I find the connector
Big_deppresion_time_14 Xxx - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 42
Todo El Tiempo: 419
