Saltar al contenido principal
Backbone One Face Buttons Replacement
Qué necesitas
  1. Backbone One Face Buttons Replacement, Remove the screws: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Face Buttons Replacement, Rotate the upper part: paso 2, imagen 1 de 3 Backbone One Face Buttons Replacement, Rotate the upper part: paso 2, imagen 2 de 3 Backbone One Face Buttons Replacement, Rotate the upper part: paso 2, imagen 3 de 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Face Buttons Replacement, Remove the protective tape: paso 3, imagen 1 de 3 Backbone One Face Buttons Replacement, Remove the protective tape: paso 3, imagen 2 de 3 Backbone One Face Buttons Replacement, Remove the protective tape: paso 3, imagen 3 de 3
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
  4. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: paso 4, imagen 1 de 3 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: paso 4, imagen 2 de 3 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: paso 4, imagen 3 de 3
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
  5. Backbone One Face Buttons Replacement, Disconnect the interconnect cable: paso 5, imagen 1 de 2 Backbone One Face Buttons Replacement, Disconnect the interconnect cable: paso 5, imagen 2 de 2
    • Disconnect the cable by pulling it straight out the ZIF connector.
  6. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: paso 6, imagen 1 de 3 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: paso 6, imagen 2 de 3 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: paso 6, imagen 3 de 3
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
  7. Backbone One Face Buttons Replacement, Separate the upper case: paso 7, imagen 1 de 1
    • Separate the the upper case of the left controller handle.
  8. Backbone One Face Buttons Replacement, Remove the screws: paso 8, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
  9. Backbone One Face Buttons Replacement, Remove the trigger: paso 9, imagen 1 de 2 Backbone One Face Buttons Replacement, Remove the trigger: paso 9, imagen 2 de 2
    • Remove the trigger.
  10. Backbone One Face Buttons Replacement, Remove the bumper: paso 10, imagen 1 de 2 Backbone One Face Buttons Replacement, Remove the bumper: paso 10, imagen 2 de 2
    • Remove the bumper.
  11. Backbone One Face Buttons Replacement, Remove the screws: paso 11, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
  12. Backbone One Face Buttons Replacement, Remove the mainboard: paso 12, imagen 1 de 3 Backbone One Face Buttons Replacement, Remove the mainboard: paso 12, imagen 2 de 3 Backbone One Face Buttons Replacement, Remove the mainboard: paso 12, imagen 3 de 3
    • Remove the mainboard.
  13. Backbone One Face Buttons Replacement, Remove the rubber cover: paso 13, imagen 1 de 3 Backbone One Face Buttons Replacement, Remove the rubber cover: paso 13, imagen 2 de 3 Backbone One Face Buttons Replacement, Remove the rubber cover: paso 13, imagen 3 de 3
    • Use a pair of blunt nose tweezers to remove the rubber cover which is placed over the face buttons.
  14. Backbone One Face Buttons Replacement, Remove the face buttons: paso 14, imagen 1 de 3 Backbone One Face Buttons Replacement, Remove the face buttons: paso 14, imagen 2 de 3 Backbone One Face Buttons Replacement, Remove the face buttons: paso 14, imagen 3 de 3
    • Use a pair of tweezers to remove the face buttons.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
Adriana Zwink
Miembro Desde 12/18/19
43,460 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
136 Miembros
15,122 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 76
Todo El Tiempo: 1,274
