Saltar al contenido principal
Back Panel Removal
Qué necesitas
  1. Back Panel Removal, Battery: paso 1, imagen 1 de 1
    • Power down the computer and unplug the power adapter.
  2. Back Panel Removal: paso 2, imagen 1 de 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Back Panel Removal: paso 3, imagen 1 de 3 Back Panel Removal: paso 3, imagen 2 de 3 Back Panel Removal: paso 3, imagen 3 de 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Back Panel Removal, Back Panel Removal: paso 4, imagen 1 de 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Back Panel Removal: paso 5, imagen 1 de 2 Back Panel Removal: paso 5, imagen 2 de 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
Conclusión
To replace the back panel, follow the steps in reverse.
2 personas más completaron esta guía.
Austin Bons
Miembro Desde 09/22/16
1,131 Reputación
8 Guías creadas
Equipo
UC Davis, Team 2-2, Oliver Fall 2016 Miembro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 59
Todo El Tiempo: 7,467
