Saltar al contenido principal
Introducción
This guide will provide you with simple steps on how to open the back cover off an Acer Chromebook C720-2420.
  1. Place your Chromebook upside down. Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Use the plastic opening tool to carefully remove the bottom.
    • Use the plastic opening tool to carefully remove the bottom.
Conclusión
Lordan Cala
Miembro Desde 12/02/18
130 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S15-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 39
