Saltar al contenido principal
Back Cover Removal
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Back Cover Removal, Back Cover Removal: paso 1, imagen 1 de 2 Back Cover Removal, Back Cover Removal: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Back Cover Removal: paso 2, imagen 1 de 2 Back Cover Removal: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Back Cover Removal: paso 3, imagen 1 de 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Back Cover Removal: paso 4, imagen 1 de 3 Back Cover Removal: paso 4, imagen 2 de 3 Back Cover Removal: paso 4, imagen 3 de 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 17
Todo El Tiempo: 67
