Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
BUSY Bar Disassembly
Qué necesitas
  1. BUSY Bar Disassembly, Remove the back cover: paso 1, imagen 1 de 3 BUSY Bar Disassembly, Remove the back cover: paso 1, imagen 2 de 3 BUSY Bar Disassembly, Remove the back cover: paso 1, imagen 3 de 3
    • The back cover is held in place by 8 clips.
    • Use a plastic card to release one of the clips near the center at the bottom of the back cover.
    • Gently release the remaining clips until the back cover comes off completely.
  2. BUSY Bar Disassembly, Remove the screws: paso 2, imagen 1 de 3 BUSY Bar Disassembly, Remove the screws: paso 2, imagen 2 de 3 BUSY Bar Disassembly, Remove the screws: paso 2, imagen 3 de 3
    • Use a PH1 Phillips screwdriver to remove 1 screw from the bottom and 4 screws from the back of the device.
  3. BUSY Bar Disassembly, Pull out the front display unit: paso 3, imagen 1 de 3 BUSY Bar Disassembly, Pull out the front display unit: paso 3, imagen 2 de 3 BUSY Bar Disassembly, Pull out the front display unit: paso 3, imagen 3 de 3
    • Do not pull the display unit too far out of the housing, as this may damage the display cable or connectors.
    • Do not disconnect the display cable. Always disconnect the battery first to prevent a short circuit when disconnecting flat cables.
    • Use a plastic card to release the 2 latches on top of the front display.
    • Gently pull the front display unit out toward the right.
  4. BUSY Bar Disassembly, Remove the battery: paso 4, imagen 1 de 3 BUSY Bar Disassembly, Remove the battery: paso 4, imagen 2 de 3 BUSY Bar Disassembly, Remove the battery: paso 4, imagen 3 de 3
    • Gently move the battery to the left so you can access the connector.
    • Use tweezers or your fingertip to press the connector latch.
    • Pull the battery connector to disconnect it from the PCB.
  5. BUSY Bar Disassembly, Remove the front display unit: paso 5, imagen 1 de 3 BUSY Bar Disassembly, Remove the front display unit: paso 5, imagen 2 de 3 BUSY Bar Disassembly, Remove the front display unit: paso 5, imagen 3 de 3
    • Use a spudger to release the display cable connector latch.
    • Pull the cable in the direction indicated by the arrow.
    • Remove the front display unit.
  6. BUSY Bar Disassembly, Remove the battery pad: paso 6, imagen 1 de 2 BUSY Bar Disassembly, Remove the battery pad: paso 6, imagen 2 de 2
    • Use your fingers to lift and remove the silicone battery pad.
  7. BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: paso 7, imagen 1 de 3 BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: paso 7, imagen 2 de 3 BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: paso 7, imagen 3 de 3
    • Use tweezers to remove the yellow tape from the connector on the main PCB.
    • Use a halberd spudger to release the connector latch.
    • Use tweezers to disconnect the cable from the connector.
  8. BUSY Bar Disassembly, Disconnect the back display: paso 8, imagen 1 de 2 BUSY Bar Disassembly, Disconnect the back display: paso 8, imagen 2 de 2
    • Use a halberd spudger to release the latch on the display connector.
    • Gently press the flex cable with your finger and slide it out of the connector.
  9. BUSY Bar Disassembly, Remove the speaker: paso 9, imagen 1 de 3 BUSY Bar Disassembly, Remove the speaker: paso 9, imagen 2 de 3 BUSY Bar Disassembly, Remove the speaker: paso 9, imagen 3 de 3
    • Use a spudger to pry up the speaker connector and disconnect it.
    • Use tweezers to remove the speaker from the device housing.
  10. BUSY Bar Disassembly, Remove the control knobs: paso 10, imagen 1 de 3 BUSY Bar Disassembly, Remove the control knobs: paso 10, imagen 2 de 3 BUSY Bar Disassembly, Remove the control knobs: paso 10, imagen 3 de 3
    • Use a spudger or an opening tool to remove the scroll wheel, holding it with your other hand to prevent bending.
    • Using both hands, lift up the Start/Pause button knob to remove it.
    • Use a spudger or an opening tool to remove the mode selector cover.
  11. BUSY Bar Disassembly, Remove the main PCB: paso 11, imagen 1 de 3 BUSY Bar Disassembly, Remove the main PCB: paso 11, imagen 2 de 3 BUSY Bar Disassembly, Remove the main PCB: paso 11, imagen 3 de 3
    • Use a PH1 screwdriver to remove the 3 screws securing the PCB.
    • Carefully lift the PCB out of the device housing.
  12. BUSY Bar Disassembly, Remove the control unit: paso 12, imagen 1 de 3 BUSY Bar Disassembly, Remove the control unit: paso 12, imagen 2 de 3 BUSY Bar Disassembly, Remove the control unit: paso 12, imagen 3 de 3
    • Peel off the 2 black stickers from the control unit.
    • Use a spudger to release the 2 clips on the sides of the unit.
    • Use a halberd spudger to release the 2 clips closer to the center.
    • Remove the control unit from the device housing.
  13. BUSY Bar Disassembly, Remove the Back button cap and the light guides: paso 13, imagen 1 de 3 BUSY Bar Disassembly, Remove the Back button cap and the light guides: paso 13, imagen 2 de 3 BUSY Bar Disassembly, Remove the Back button cap and the light guides: paso 13, imagen 3 de 3
    • Remove the 2 white status indicator light guides by lifting them from the edge with your finger.
    • Use a spudger to release the latch securing the Back button cover.
    • Remove the Back button cover.
  14. BUSY Bar Disassembly, Remove the button stabilizer: paso 14, imagen 1 de 3 BUSY Bar Disassembly, Remove the button stabilizer: paso 14, imagen 2 de 3 BUSY Bar Disassembly, Remove the button stabilizer: paso 14, imagen 3 de 3
    • Remove the 3 screws from the bottom of the control unit.
    • Remove the stabilizer holder.
  15. BUSY Bar Disassembly, Remove the control PCB from the housing: paso 15, imagen 1 de 3 BUSY Bar Disassembly, Remove the control PCB from the housing: paso 15, imagen 2 de 3 BUSY Bar Disassembly, Remove the control PCB from the housing: paso 15, imagen 3 de 3
    • The control PCB is secured in the plastic housing by 5 latches.
    • Gently pull the PCB away from the plastic housing. You can pull by the scroll wheel or the mode selector.
    • Release the latches by bending them outward from the PCB using your finger, a spudger, or an opening tool.
    • Once all latches are released, remove the PCB from the housing.
  16. BUSY Bar Disassembly, Disconnect the cable from the control PCB: paso 16, imagen 1 de 2 BUSY Bar Disassembly, Disconnect the cable from the control PCB: paso 16, imagen 2 de 2
    • Use a spudger to carefully release the connector latch.
    • Remove the flex cable.
  17. BUSY Bar Disassembly, Remove the front display back cover: paso 17, imagen 1 de 3 BUSY Bar Disassembly, Remove the front display back cover: paso 17, imagen 2 de 3 BUSY Bar Disassembly, Remove the front display back cover: paso 17, imagen 3 de 3
    • The back cover of the front display unit is secured by 6 latches.
    • Use a spudger or a plastic card to carefully release the latches around the front display.
    • Remove the back cover of the front display unit.
  18. BUSY Bar Disassembly, Disassemble the front display unit: paso 18, imagen 1 de 3 BUSY Bar Disassembly, Disassemble the front display unit: paso 18, imagen 2 de 3 BUSY Bar Disassembly, Disassemble the front display unit: paso 18, imagen 3 de 3
    • The front display unit consists of a display PCB with LEDs and LED drivers, a plastic light separator, a matte light-diffusing film, and an outer tinted glass.
    • Remove the display PCB from the front display unit.
    • Remove the light separator.
    • Remove the light-diffusing film.
  19. BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: paso 19, imagen 1 de 3 BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: paso 19, imagen 2 de 3 BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: paso 19, imagen 3 de 3
    • Tilt the ambient light sensor light guide forward to disconnect it from the display PCB.
    • Use a spudger to release the flex cable connector latch.
    • Pull the flex cable in the direction indicated by the arrow to remove it.
  20. BUSY Bar Disassembly, Remove the monitor mount: paso 20, imagen 1 de 3 BUSY Bar Disassembly, Remove the monitor mount: paso 20, imagen 2 de 3 BUSY Bar Disassembly, Remove the monitor mount: paso 20, imagen 3 de 3
    • The 2 black polyurethane friction elements on the mount’s pivot create rotational resistance to hold the leg in intermediate positions.
    • Use a spudger to slide the 2 friction elements toward the center of the device. They move together with the short metal shafts and can then be removed from the housing.
    • Press the mount leg downward toward the center of the device (following the orange arrow).
    • At the same time push the mount leg sideways (following the red arrow) to release it from the slot.
    • Repeat these steps for the opposite side of the leg to remove it.
  21. BUSY Bar Disassembly, Device fully disassembled: paso 21, imagen 1 de 1
    • The device is now fully disassembled. The picture shows all its components.
Conclusión
To reassemble the device, follow these steps in reverse order.
3 personas más completaron esta guía.
Flipper Devices
Miembro Desde 06/29/22
835 Reputación
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 31
Todo El Tiempo: 420
