Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
BUSY Bar Battery Replacement
Qué necesitas
  1. BUSY Bar Battery Replacement, Remove the back cover: paso 1, imagen 1 de 3 BUSY Bar Battery Replacement, Remove the back cover: paso 1, imagen 2 de 3 BUSY Bar Battery Replacement, Remove the back cover: paso 1, imagen 3 de 3
    • The back cover is held in place by 8 clips.
    • Use a plastic card to release one of the clips near the center at the bottom of the back cover.
    • Gently release the remaining clips until the back cover comes off completely.
  2. BUSY Bar Battery Replacement, Remove the screws: paso 2, imagen 1 de 3 BUSY Bar Battery Replacement, Remove the screws: paso 2, imagen 2 de 3 BUSY Bar Battery Replacement, Remove the screws: paso 2, imagen 3 de 3
    • Use a PH1 Phillips screwdriver to remove 1 screw from the bottom and 4 screws from the back of the device.
  3. BUSY Bar Battery Replacement, Pull out the front display unit: paso 3, imagen 1 de 3 BUSY Bar Battery Replacement, Pull out the front display unit: paso 3, imagen 2 de 3 BUSY Bar Battery Replacement, Pull out the front display unit: paso 3, imagen 3 de 3
    • Do not pull the display unit too far out of the housing, as this may damage the display cable or connectors.
    • Do not disconnect the display cable. Always disconnect the battery first to prevent a short circuit when disconnecting flat cables.
    • Use a plastic card to release the 2 latches on top of the front display.
    • Gently pull the front display unit out toward the right.
  4. BUSY Bar Battery Replacement, Remove the battery: paso 4, imagen 1 de 3 BUSY Bar Battery Replacement, Remove the battery: paso 4, imagen 2 de 3 BUSY Bar Battery Replacement, Remove the battery: paso 4, imagen 3 de 3
    • Gently move the battery to the left so you can access the connector.
    • Use tweezers or your fingertip to press the connector latch.
    • Pull the battery connector to disconnect it from the PCB.
Conclusión
Flipper Devices
Miembro Desde 06/29/22
835 Reputación
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 206
