Introducción
Using a hex 2.0 driver, you will remove the top cover. using a pair of tweezers, you will then be able to remove and replace the Brck Motherboard.
Qué necesitas
Remove the nut and washer from the RF connector, located where the antenna was connected.
Casi Terminas!
Conclusión
