Saltar al contenido principal
BRCK v1 Motherboard Replacement
Qué necesitas
  1. BRCK v1 Motherboard  Replacement, Antenna: paso 1, imagen 1 de 1
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Motherboard  Replacement: paso 2, imagen 1 de 2 BRCK v1 Motherboard  Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Motherboard  Replacement, Top Cover: paso 3, imagen 1 de 1
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Motherboard  Replacement: paso 4, imagen 1 de 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Motherboard  Replacement: paso 5, imagen 1 de 1
    • Remove the top cover.
  6. BRCK v1 Motherboard  Replacement, Modem: paso 6, imagen 1 de 1
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  7. BRCK v1 Motherboard  Replacement: paso 7, imagen 1 de 1
    • Remove the connection located on the edge of the modem.
  8. BRCK v1 Motherboard  Replacement: paso 8, imagen 1 de 2 BRCK v1 Motherboard  Replacement: paso 8, imagen 2 de 2
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  9. BRCK v1 Motherboard  Replacement: paso 9, imagen 1 de 3 BRCK v1 Motherboard  Replacement: paso 9, imagen 2 de 3 BRCK v1 Motherboard  Replacement: paso 9, imagen 3 de 3
    Comprar
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  10. BRCK v1 Motherboard  Replacement: paso 10, imagen 1 de 2 BRCK v1 Motherboard  Replacement: paso 10, imagen 2 de 2
    • Remove the modem from the device.
  11. BRCK v1 Motherboard  Replacement, Motherboard: paso 11, imagen 1 de 2 BRCK v1 Motherboard  Replacement, Motherboard: paso 11, imagen 2 de 2
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  12. BRCK v1 Motherboard  Replacement: paso 12, imagen 1 de 2 BRCK v1 Motherboard  Replacement: paso 12, imagen 2 de 2
    • Unplug the red, black, and yellow wire connection by lifting up.
  13. BRCK v1 Motherboard  Replacement: paso 13, imagen 1 de 3 BRCK v1 Motherboard  Replacement: paso 13, imagen 2 de 3 BRCK v1 Motherboard  Replacement: paso 13, imagen 3 de 3
    Comprar
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  14. BRCK v1 Motherboard  Replacement: paso 14, imagen 1 de 1
    • Remove outside rubber covers by lifting them out of place.
  15. BRCK v1 Motherboard  Replacement: paso 15, imagen 1 de 3 BRCK v1 Motherboard  Replacement: paso 15, imagen 2 de 3 BRCK v1 Motherboard  Replacement: paso 15, imagen 3 de 3
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
Conclusión
Jeret Buerger
Miembro Desde 04/01/15
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-3, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 237
