Introducción
This guide will show you how to remove the top case of the device utilizing a hex 2.0 drive. This allows you to access the modem. Using a pair of tweezers, you can easily remove the modem and replace the ribbon connector located underneath.
Qué necesitas
Using your fingers, apply equal force to each side of the black tab to loosen the connection.
Slide the ribbon out from under the black tab.
