Saltar al contenido principal
BRCK v1 Modem Ribbon Connector Replacement
Qué necesitas
  1. BRCK v1 Modem Ribbon Connector Replacement, Top Cover: paso 1, imagen 1 de 1
    • Place the face of the device showing BRCK face up.
  2. BRCK v1 Modem Ribbon Connector Replacement: paso 2, imagen 1 de 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  3. BRCK v1 Modem Ribbon Connector Replacement: paso 3, imagen 1 de 1
    • Remove the top cover.
  4. BRCK v1 Modem Ribbon Connector Replacement, Modem: paso 4, imagen 1 de 1
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  5. BRCK v1 Modem Ribbon Connector Replacement: paso 5, imagen 1 de 1
    • Remove the connection located on the edge of the modem.
  6. BRCK v1 Modem Ribbon Connector Replacement: paso 6, imagen 1 de 2 BRCK v1 Modem Ribbon Connector Replacement: paso 6, imagen 2 de 2
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  7. BRCK v1 Modem Ribbon Connector Replacement: paso 7, imagen 1 de 3 BRCK v1 Modem Ribbon Connector Replacement: paso 7, imagen 2 de 3 BRCK v1 Modem Ribbon Connector Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  8. BRCK v1 Modem Ribbon Connector Replacement: paso 8, imagen 1 de 2 BRCK v1 Modem Ribbon Connector Replacement: paso 8, imagen 2 de 2
    • Remove the modem from the device.
  9. BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: paso 9, imagen 1 de 3 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: paso 9, imagen 2 de 3 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: paso 9, imagen 3 de 3
    • Using your fingers, apply equal force to each side of the black tab to loosen the connection.
    • Slide the ribbon out from under the black tab.
Conclusión
Jeret Buerger
Miembro Desde 04/01/15
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-3, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 180
