Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
BRCK v1 Modem Replacement
Qué necesitas
    1. BRCK v1 Modem  Replacement, Top Cover: paso 1, imagen 1 de 1
      • Place the face of the device showing BRCK face up.
      Pregunta a FixBot
      Agregar Comentario
    2. BRCK v1 Modem  Replacement: paso 2, imagen 1 de 1
      • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    3. BRCK v1 Modem  Replacement: paso 3, imagen 1 de 1
      • Remove the top cover.
      Pregunta a FixBot
      Agregar Comentario
    1. BRCK v1 Modem  Replacement, Modem: paso 4, imagen 1 de 1
      • Cut the black zip tie holding the modem down.
      • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
      Pregunta a FixBot
      Agregar Comentario
    2. BRCK v1 Modem  Replacement: paso 5, imagen 1 de 1
      • Remove the connection located on the edge of the modem.
      Pregunta a FixBot
      Agregar Comentario
    3. BRCK v1 Modem  Replacement: paso 6, imagen 1 de 2 BRCK v1 Modem  Replacement: paso 6, imagen 2 de 2
      • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
      Pregunta a FixBot
      Agregar Comentario
    4. BRCK v1 Modem  Replacement: paso 7, imagen 1 de 3 BRCK v1 Modem  Replacement: paso 7, imagen 2 de 3 BRCK v1 Modem  Replacement: paso 7, imagen 3 de 3
      Herramienta utilizada en este paso:
      • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
      • Lower the plate and gently pull the ribbon out of the face plate.
      • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
      Pregunta a FixBot
      Agregar Comentario
    5. BRCK v1 Modem  Replacement: paso 8, imagen 1 de 2 BRCK v1 Modem  Replacement: paso 8, imagen 2 de 2
      • Remove the modem from the device.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Jeret Buerger
Miembro Desde 04/01/15
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-3, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
Miembros de 3
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 501
