Saltar al contenido principal
BRCK v1 Battery Replacement
Qué necesitas
  1. BRCK v1 Battery Replacement, Antenna: paso 1, imagen 1 de 1
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Battery Replacement: paso 2, imagen 1 de 2 BRCK v1 Battery Replacement: paso 2, imagen 2 de 2
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Battery Replacement, Top Cover: paso 3, imagen 1 de 1
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the top cover.
  6. BRCK v1 Battery Replacement, Motherboard: paso 6, imagen 1 de 2 BRCK v1 Battery Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  7. BRCK v1 Battery Replacement: paso 7, imagen 1 de 2 BRCK v1 Battery Replacement: paso 7, imagen 2 de 2
    • Unplug the red, black, and yellow wire connection by lifting up.
  8. BRCK v1 Battery Replacement: paso 8, imagen 1 de 3 BRCK v1 Battery Replacement: paso 8, imagen 2 de 3 BRCK v1 Battery Replacement: paso 8, imagen 3 de 3
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  9. BRCK v1 Battery Replacement: paso 9, imagen 1 de 1
    • Remove outside rubber covers by lifting them out of place.
  10. BRCK v1 Battery Replacement: paso 10, imagen 1 de 3 BRCK v1 Battery Replacement: paso 10, imagen 2 de 3 BRCK v1 Battery Replacement: paso 10, imagen 3 de 3
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
  11. BRCK v1 Battery Replacement, Battery: paso 11, imagen 1 de 3 BRCK v1 Battery Replacement, Battery: paso 11, imagen 2 de 3 BRCK v1 Battery Replacement, Battery: paso 11, imagen 3 de 3
    • Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
    • This may take a few tries to remove the battery.
Conclusión
Jeret Buerger
Miembro Desde 04/01/15
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-3, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 206
