Introducción
This guide will use a hex 2.0 head to open the case, as well as tweezers to disconnect and remove the motherboard. This will allow you to access the battery located at the bottom of the case.
Qué necesitas
Remove the nut and washer from the RF connector, located where the antenna was connected.
Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
Casi Terminas!
Conclusión
