Saltar al contenido principal
BOSE SoundTouch 30 Motherboard Replacement
Qué necesitas
  1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: paso 1, imagen 1 de 2 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: paso 1, imagen 2 de 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: paso 2, imagen 1 de 1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Motherboard Replacement: paso 3, imagen 1 de 2 BOSE SoundTouch 30 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  4. BOSE SoundTouch 30 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
  5. BOSE SoundTouch 30 Motherboard Replacement: paso 5, imagen 1 de 2 BOSE SoundTouch 30 Motherboard Replacement: paso 5, imagen 2 de 2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
  6. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
Conclusión
4 personas más completaron esta guía.
Brennen Irey
Miembro Desde 04/18/18
1,017 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S16-G2, Livingston Spring 2018 Miembro de Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Miembros
6 Guías creadas
3 comentarios
Where do I can get the power supply?
Ulises Peña - Contestar
where can i get the notherboard? 354437-0060
guillermo gibson - Contestar
Please where can I get the motherboard
Marjorie Newell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 50
Todo El Tiempo: 5,122
