Saltar al contenido principal
BOSE SoundTouch 30 Display Assembly Replacement
Qué necesitas
  1. BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: paso 1, imagen 1 de 2 BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: paso 1, imagen 2 de 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Display Assembly Replacement, Display Assembly: paso 2, imagen 1 de 1
    • Remove the three 15.5mm PH2 screws holding the front-mesh grille in place.
  3. BOSE SoundTouch 30 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the grille by gripping the edges and pulling upwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  4. BOSE SoundTouch 30 Display Assembly Replacement: paso 4, imagen 1 de 2 BOSE SoundTouch 30 Display Assembly Replacement: paso 4, imagen 2 de 2
    • Remove the six 8.9mm T9 torx screws holding the display assembly down.
    • The display assembly can now be lifted out of the grille so that a new one can be put in.
Conclusión
2 personas más completaron esta guía.
Brennen Irey
Miembro Desde 04/18/18
993 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S16-G2, Livingston Spring 2018 Miembro de Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Miembros
6 Guías creadas
Un comentario
Display assembly price
imrankhannnnn786 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 45
Todo El Tiempo: 3,090
