Saltar al contenido principal
BLU WIN HD LTE Speaker Replacement
Qué necesitas
  1. BLU WIN HD LTE Speaker Replacement, Back Case: paso 1, imagen 1 de 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Speaker Replacement: paso 2, imagen 1 de 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Speaker Replacement, Frame Cover: paso 3, imagen 1 de 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Speaker Replacement: paso 4, imagen 1 de 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Speaker Replacement, Speaker: paso 5, imagen 1 de 3 BLU WIN HD LTE Speaker Replacement, Speaker: paso 5, imagen 2 de 3 BLU WIN HD LTE Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • Use the spudger to pry out the speaker from the Frame Cover.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 140
