Saltar al contenido principal
BLU WIN HD LTE Battery Replacement
Qué necesitas
  1. BLU WIN HD LTE Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: paso 2, imagen 1 de 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: paso 3, imagen 1 de 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: paso 4, imagen 1 de 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: paso 5, imagen 1 de 2 BLU WIN HD LTE Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Conclusión
2 comentarios
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Contestar
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 662
