Introducción
Use this guide to replace any piece inside your BLU Vivo 5 Mini.
This guide instructs you to remove the back panel encasing; with the purpose to remove internal items such as battery, camera, speaker, charging port etc.
For better performance and a longer lasting charge: Drain battery below 10% , and then proceed to charge it without interruptions to 100%.
Qué necesitas
Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
You can also use steps 1-4 for any other internal replacement.
Una persona más ha completado esta guía.
