Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Replacement guide for the BLU Vivo 5's battery
Technical information:
https://www.gsmarena.com/blu_vivo_5-7857...
  1. Remove the P2 screws. Remove the SIM and SD cards, as well as the adapter.
    • Remove the P2 screws.
    • Remove the SIM and SD cards, as well as the adapter.
  2. Pull off the protective cover from the camera. Remove the screws with a #00 Phillips screwdriver. Remove the screws with a #00 Phillips screwdriver.
    • Pull off the protective cover from the camera.
    • Remove the screws with a #00 Phillips screwdriver.
  3. To remove the bottom cover, pull it upward. To remove the bottom cover, pull it upward. To remove the bottom cover, pull it upward.
    • To remove the bottom cover, pull it upward.
  4. Use a spudger to carefully apply pressure to the indicated areas to remove the cover. Remove the microphone/speaker board assembly by pulling downward. Remove the microphone/speaker board assembly by pulling downward.
    • Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
    • Remove the microphone/speaker board assembly by pulling downward.
  5. The battery has a small notch to facilitate removal, but the battery has been glued in place. To gently remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose. To gently remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
    • The battery has a small notch to facilitate removal, but the battery has been glued in place.
    • To gently remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
Conclusión
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Eneider Colina
Miembro Desde 20/09/13
1,444 Reputación
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 99
Todo El Tiempo: 1,454
