Saltar al contenido principal
BLU Tank II Motherboard Replacement
Qué necesitas
  1. BLU Tank II Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 BLU Tank II Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Motherboard Replacement, Battery: paso 2, imagen 1 de 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Motherboard Replacement, Front Panel: paso 3, imagen 1 de 2 BLU Tank II Motherboard Replacement, Front Panel: paso 3, imagen 2 de 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Motherboard Replacement: paso 4, imagen 1 de 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 BLU Tank II Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Locate the two 2.5mm screws (red circles in image) and remove them with the Philips 00 screwdriver used previously.
  6. BLU Tank II Motherboard Replacement: paso 6, imagen 1 de 3 BLU Tank II Motherboard Replacement: paso 6, imagen 2 de 3 BLU Tank II Motherboard Replacement: paso 6, imagen 3 de 3
    • Once screws are removed, separate the motherboard and outer lens by carefully pushing the motherboard out with your hand as displayed in the image.
Conclusión
Una persona más ha completado esta guía.
David Kelchner
Miembro Desde 03/08/17
632 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 301
