Saltar al contenido principal
BLU Tank II Keypad Replacement
Qué necesitas
  1. BLU Tank II Keypad Replacement, Back Panel: paso 1, imagen 1 de 2 BLU Tank II Keypad Replacement, Back Panel: paso 1, imagen 2 de 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Keypad Replacement, Battery: paso 2, imagen 1 de 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Keypad Replacement, Front Panel: paso 3, imagen 1 de 2 BLU Tank II Keypad Replacement, Front Panel: paso 3, imagen 2 de 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Keypad Replacement: paso 4, imagen 1 de 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Keypad Replacement, Keypad: paso 5, imagen 1 de 3 BLU Tank II Keypad Replacement, Keypad: paso 5, imagen 2 de 3 BLU Tank II Keypad Replacement, Keypad: paso 5, imagen 3 de 3
    • Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
    • Peel the keypad out from the keyholes in the front plate.
Conclusión
David Kelchner
Miembro Desde 03/08/17
632 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 138
