Saltar al contenido principal
BLU Tank II Front Panel Replacement
Qué necesitas
  1. BLU Tank II Front Panel Replacement, Back Panel: paso 1, imagen 1 de 2 BLU Tank II Front Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Front Panel Replacement, Battery: paso 2, imagen 1 de 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Front Panel Replacement, Front Panel: paso 3, imagen 1 de 2 BLU Tank II Front Panel Replacement, Front Panel: paso 3, imagen 2 de 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Front Panel Replacement: paso 4, imagen 1 de 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
Conclusión
David Kelchner
Miembro Desde 03/08/17
632 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 214
