Introducción
Use this guide to fix a broken or cracked screen on the BLU Studio G. The replacement will require a near complete disassembly of the phone since the connections to the motherboard will have to be disengaged.
Qué necesitas
Paso 1 Motherboard Prerequisite
Aviso: los pasos 1-8 provienen de una guía que está marcada como "En progreso".
To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
Locate the two connector clamps on the motherboard.
Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
Herramienta utilizada en este paso:Tweezers$4.99
Turn the phone over after detaching the connectors that were attached to the motherboard
Carefully pry between the screen and the bevel with precision tweezers lifting slowly separating the screen.
Use of another thin tool will help support the lifting
Insert the metal spudger between the screen and the frame, using the blue plastic tool as a brace to prevent the screen from reattaching to the frame.
To fully remove the screen from the frame, repeat the previous step around the entire perimeter of the device.
Carefully remove the screen.
4 personas más completaron esta guía.
5Guía Comentarios
Can anyone tell me where I can buy a screen for a blu view 3
Thank you
mrcblake50@gmail.com
I need screen fue the sam3 ministerio blu.where to buy
