Saltar al contenido principal
BLU Studio 7.0 II Back Cover Replacement
Qué necesitas
  1. BLU Studio 7.0 II Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Locate the seam between the black and silver pieces of the phone.
    • Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
    • To create the initial separation for the plastic opening tool, you may need to use either a spudger or metal spudger. If you use a metal spudger, be aware this can damage your phone if you aren't careful.
  2. BLU Studio 7.0 II Back Cover Replacement: paso 2, imagen 1 de 1
    • Work your way around the edge of phone, firmly prying the pieces apart.
  3. BLU Studio 7.0 II Back Cover Replacement: paso 3, imagen 1 de 2 BLU Studio 7.0 II Back Cover Replacement: paso 3, imagen 2 de 2
    • Once the back has been removed, you can snap the new one into place by pressing firmly around the edges with your fingers.
Linea de Meta
5 personas más completaron esta guía.
Abby
Miembro Desde 05/14/16
852 Reputación
5 Guías creadas
Equipo
Metro State, Team 1-2, Carpenter SU 2016 Miembro de Metro State, Team 1-2, Carpenter SU 2016
MSU-CARPENTER-SU16S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 38
Todo El Tiempo: 2,106
