Saltar al contenido principal
BLU Studio 5.5 Motherboard Replacement
Qué necesitas
  1. BLU Studio 5.5 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 BLU Studio 5.5 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 BLU Studio 5.5 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. BLU Studio 5.5 Motherboard Replacement: paso 2, imagen 1 de 2 BLU Studio 5.5 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. BLU Studio 5.5 Motherboard Replacement: paso 3, imagen 1 de 3 BLU Studio 5.5 Motherboard Replacement: paso 3, imagen 2 de 3 BLU Studio 5.5 Motherboard Replacement: paso 3, imagen 3 de 3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. BLU Studio 5.5 Motherboard Replacement, Back Panel Assembly: paso 4, imagen 1 de 2 BLU Studio 5.5 Motherboard Replacement, Back Panel Assembly: paso 4, imagen 2 de 2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. BLU Studio 5.5 Motherboard Replacement: paso 5, imagen 1 de 3 BLU Studio 5.5 Motherboard Replacement: paso 5, imagen 2 de 3 BLU Studio 5.5 Motherboard Replacement: paso 5, imagen 3 de 3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. BLU Studio 5.5 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 BLU Studio 5.5 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 BLU Studio 5.5 Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Locate the motherboard that is above where the battery was removed.
    • Remove the three screws holding down the motherboard to the phone.
    • Locate all 7 flex cable connectors that are attached to the motherboard.
  7. BLU Studio 5.5 Motherboard Replacement: paso 7, imagen 1 de 3 BLU Studio 5.5 Motherboard Replacement: paso 7, imagen 2 de 3 BLU Studio 5.5 Motherboard Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Use tweezers to carefully grasp and unhook all 7 flex cable connectors.
    • With the same tweezers, pry off the cable clasp that connects the motherboard to the sub PCBA.
    • Once the motherboard is disconnected from all components, use the tweezers or your fingers to remove it from the phone assembly.
    • Use the Anti-Static Wrist Strap to eliminate the possibility of introducing a static force that may damage the motherboard components.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G6, Nance Spring 2017 Miembro de USF Tampa, Team S1-G6, Nance Spring 2017
USFT-NANCE-S17S1G6
3 Miembros
8 Guías creadas
Un comentario
Can you do a BLU vivo XL4 Teardown?
Michael18751 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,487
