Saltar al contenido principal
BLU Studio 5.0 S II Screen Replacement
Qué necesitas
  1. BLU Studio 5.0 S II Screen Replacement, Remove back cover: paso 1, imagen 1 de 1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Screen Replacement, Remove battery: paso 2, imagen 1 de 1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Screen Replacement, Motherboard: paso 3, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Screen Replacement: paso 4, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 4, imagen 2 de 2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Screen Replacement: paso 5, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 5, imagen 2 de 2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Screen Replacement: paso 6, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 6, imagen 2 de 2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Screen Replacement: paso 7, imagen 1 de 3 BLU Studio 5.0 S II Screen Replacement: paso 7, imagen 2 de 3 BLU Studio 5.0 S II Screen Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Screen Replacement: paso 8, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 8, imagen 2 de 2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Screen Replacement: paso 9, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 9, imagen 2 de 2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Screen Replacement: paso 10, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 10, imagen 2 de 2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Screen Replacement: paso 11, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 11, imagen 2 de 2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Screen Replacement: paso 12, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement: paso 12, imagen 2 de 2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Screen Replacement: paso 13, imagen 1 de 1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
  14. BLU Studio 5.0 S II Screen Replacement, Screen: paso 14, imagen 1 de 2 BLU Studio 5.0 S II Screen Replacement, Screen: paso 14, imagen 2 de 2
    • Peel off the bottom back with finger or supdger.
    • CAUTION: Adhesive is attached to the bottom circuitboard. May require extra effort to remove.
Conclusión
To reassemble your device, follow these instructions in reverse order with the screen replacement.
2 personas más completaron esta guía.
Equipo
IUPUI, Team S2-G3, Harley Spring 2017 Miembro de IUPUI, Team S2-G3, Harley Spring 2017
IUPUI-HARLEY-S17S2G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 782
