Introducción
Having issues with your volume control buttons? This guide instructs you to detach the rear panel assembly in addition to the rear plate and replace the volume control buttons.
Qué necesitas
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Remove the battery by lifting the lower edge of the battery up first.
