Saltar al contenido principal
BLU Life XL Volume Control Buttons Replacement
Qué necesitas
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: paso 1, imagen 1 de 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: paso 1, imagen 2 de 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: paso 1, imagen 3 de 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Volume Control Buttons Replacement: paso 2, imagen 1 de 2 BLU Life XL Volume Control Buttons Replacement: paso 2, imagen 2 de 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Volume Control Buttons Replacement: paso 3, imagen 1 de 2 BLU Life XL Volume Control Buttons Replacement: paso 3, imagen 2 de 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Volume Control Buttons Replacement: paso 4, imagen 1 de 3 BLU Life XL Volume Control Buttons Replacement: paso 4, imagen 2 de 3 BLU Life XL Volume Control Buttons Replacement: paso 4, imagen 3 de 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
Conclusión
James Whitlow
Miembro Desde 02/14/18
342 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S2-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 286
