Saltar al contenido principal
BLU Life XL Rear Camera Replacement
Qué necesitas
  1. BLU Life XL Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 3 BLU Life XL Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 3 BLU Life XL Rear Camera Replacement, Rear Camera: paso 1, imagen 3 de 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Rear Camera Replacement: paso 2, imagen 1 de 2 BLU Life XL Rear Camera Replacement: paso 2, imagen 2 de 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Rear Camera Replacement: paso 3, imagen 1 de 2 BLU Life XL Rear Camera Replacement: paso 3, imagen 2 de 2
    • Insert the plastic prying tool in between the plastic frame and the device.
    • Keep the phone on the surface with its screen down.
  4. BLU Life XL Rear Camera Replacement: paso 4, imagen 1 de 2 BLU Life XL Rear Camera Replacement: paso 4, imagen 2 de 2
    • Use the plastic prying tool to gently push the rear camera out from its socket.
    • Take the camera out and set it aside.
  5. BLU Life XL Rear Camera Replacement: paso 5, imagen 1 de 2 BLU Life XL Rear Camera Replacement: paso 5, imagen 2 de 2
    • Carefully place the new camera in the camera socket.
    • Apply a little force on the top of the camera to slide it in the socket.
    • Pop the camera in the socket and make sure its stable.
Conclusión
Shantanu Malhotra
Miembro Desde 02/14/18
178 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S2-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 245
