Saltar al contenido principal
BLU Life XL Charging Port Replacement
Qué necesitas
  1. BLU Life XL Charging Port Replacement, Battery: paso 1, imagen 1 de 3 BLU Life XL Charging Port Replacement, Battery: paso 1, imagen 2 de 3 BLU Life XL Charging Port Replacement, Battery: paso 1, imagen 3 de 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  2. BLU Life XL Charging Port Replacement: paso 2, imagen 1 de 3 BLU Life XL Charging Port Replacement: paso 2, imagen 2 de 3 BLU Life XL Charging Port Replacement: paso 2, imagen 3 de 3
    • Remove the old battery.
    • For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
  3. BLU Life XL Charging Port Replacement, Charging Port: paso 3, imagen 1 de 2 BLU Life XL Charging Port Replacement, Charging Port: paso 3, imagen 2 de 2
    • Remove twelve 3mm Phillips #000 screws from the rear plate.
  4. BLU Life XL Charging Port Replacement: paso 4, imagen 1 de 2 BLU Life XL Charging Port Replacement: paso 4, imagen 2 de 2
    • Remove the plastic frame on the device using an opening tool.
    • Firmly press the tool into the gap between the front glass and rear plate.
    • The gap is located on all sides of the phone.
    • Run the tool through this gap along the entire edge of the phone to separate the plastic frame from the phone.
  5. BLU Life XL Charging Port Replacement: paso 5, imagen 1 de 3 BLU Life XL Charging Port Replacement: paso 5, imagen 2 de 3 BLU Life XL Charging Port Replacement: paso 5, imagen 3 de 3
    • Disconnect lower PCB antenna connection.
    • Disconnect lower PCB data cable connection.
    • Remove the single JIS #000 3mm screw from the PCB board.
  6. BLU Life XL Charging Port Replacement: paso 6, imagen 1 de 1
    • Remove the haptic motor at bottom left of the device. This will require a prying tool, as the motor is glued to the device.
Conclusión
2 personas más completaron esta guía.
Euan Gordon
Miembro Desde 02/14/18
164 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S2-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 1,946
