Saltar al contenido principal
BLU Life X8 Screen Replacement
Qué necesitas
  1. BLU Life X8 Screen Replacement, Battery: paso 1, imagen 1 de 2 BLU Life X8 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Screen Replacement: paso 2, imagen 1 de 1
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Screen Replacement: paso 3, imagen 1 de 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Screen Replacement, Motherboard: paso 4, imagen 1 de 2 BLU Life X8 Screen Replacement, Motherboard: paso 4, imagen 2 de 2
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Screen Replacement: paso 5, imagen 1 de 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Screen Replacement: paso 6, imagen 1 de 1
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Screen Replacement: paso 7, imagen 1 de 2 BLU Life X8 Screen Replacement: paso 7, imagen 2 de 2
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Screen Replacement: paso 8, imagen 1 de 3 BLU Life X8 Screen Replacement: paso 8, imagen 2 de 3 BLU Life X8 Screen Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Screen Replacement: paso 9, imagen 1 de 1
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Screen Replacement: paso 10, imagen 1 de 1
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Screen Replacement, Daughterboard: paso 11, imagen 1 de 1
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Screen Replacement: paso 12, imagen 1 de 1
    Comprar
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Screen Replacement: paso 13, imagen 1 de 3 BLU Life X8 Screen Replacement: paso 13, imagen 2 de 3 BLU Life X8 Screen Replacement: paso 13, imagen 3 de 3
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Screen Replacement: paso 14, imagen 1 de 1
    • Lift the daughterboard from the frame using the plastic opening tool.
  15. BLU Life X8 Screen Replacement, Screen: paso 15, imagen 1 de 1
    • Take off the sticker and the ribbon cables glued to the back of the screen.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G2, Nance Fall 2017 Miembro de USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 441
