Saltar al contenido principal
BLU Life X8 Back Camera Replacement
Qué necesitas
  1. BLU Life X8 Back Camera Replacement, Battery: paso 1, imagen 1 de 2 BLU Life X8 Back Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Back Camera Replacement: paso 2, imagen 1 de 1
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Back Camera Replacement: paso 3, imagen 1 de 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Back Camera Replacement, Back Camera: paso 4, imagen 1 de 2 BLU Life X8 Back Camera Replacement, Back Camera: paso 4, imagen 2 de 2
    • Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
  5. BLU Life X8 Back Camera Replacement: paso 5, imagen 1 de 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from reengaging.
  6. BLU Life X8 Back Camera Replacement: paso 6, imagen 1 de 1
    • Once all the clips have been released, pull back the frame and set it aside.
  7. BLU Life X8 Back Camera Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to unlock the ribbon cable from the motherboard
    • The ribbon cable should be free. Pull back on the ribbons to release it from the connector
  8. BLU Life X8 Back Camera Replacement: paso 8, imagen 1 de 1
    • Lift the back camera from its housing
    • The back camera may be glued to the phone
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G2, Nance Fall 2017 Miembro de USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 240
