Saltar al contenido principal
BLU Dash Music 4.0 Speaker Replacement
Qué necesitas
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: paso 1, imagen 1 de 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: paso 2, imagen 1 de 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: paso 3, imagen 1 de 2 BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: paso 3, imagen 2 de 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: paso 4, imagen 1 de 2 BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: paso 4, imagen 2 de 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: paso 5, imagen 1 de 3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: paso 5, imagen 2 de 3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: paso 5, imagen 3 de 3
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: paso 6, imagen 1 de 1
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 497
