Saltar al contenido principal
BLU Dash JR D140 Microphone Replacement
Qué necesitas
  1. BLU Dash JR D140 Microphone Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Microphone Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Microphone Replacement, Microphone: paso 3, imagen 1 de 1
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Microphone Replacement: paso 4, imagen 1 de 2 BLU Dash JR D140 Microphone Replacement: paso 4, imagen 2 de 2
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Microphone Replacement: paso 5, imagen 1 de 1
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Microphone Replacement: paso 6, imagen 1 de 1
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Microphone Replacement: paso 7, imagen 1 de 1
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Microphone Replacement: paso 8, imagen 1 de 1
    • When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Microphone Replacement: paso 9, imagen 1 de 1
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Microphone Replacement: paso 10, imagen 1 de 1
    • Separate the screen cover from the motherboard using the plastic opening tool.
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
  11. BLU Dash JR D140 Microphone Replacement: paso 11, imagen 1 de 3 BLU Dash JR D140 Microphone Replacement: paso 11, imagen 2 de 3 BLU Dash JR D140 Microphone Replacement: paso 11, imagen 3 de 3
    • The microphone is at the bottom left corner of the phone.
    • Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
    • If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
    • Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
Conclusión
2 personas más completaron esta guía.
Equipo
UW Tacoma, Team 1-4, Liner SU 2015 Miembro de UW Tacoma, Team 1-4, Liner SU 2015
UWT-LINER-SU15S1G4
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 501
