Saltar al contenido principal
BLU Dash 3.5 Volume and Lock Button Replacement
Qué necesitas
  1. BLU Dash 3.5 Volume and Lock Button Replacement, Battery: paso 1, imagen 1 de 3 BLU Dash 3.5 Volume and Lock Button Replacement, Battery: paso 1, imagen 2 de 3 BLU Dash 3.5 Volume and Lock Button Replacement, Battery: paso 1, imagen 3 de 3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Volume and Lock Button Replacement: paso 2, imagen 1 de 2 BLU Dash 3.5 Volume and Lock Button Replacement: paso 2, imagen 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: paso 3, imagen 1 de 2 BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: paso 3, imagen 2 de 2
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Volume and Lock Button Replacement: paso 4, imagen 1 de 2 BLU Dash 3.5 Volume and Lock Button Replacement: paso 4, imagen 2 de 2
    • Remove volume and lock buttons by lifting them gently from the casing.
Conclusión
Paige Shirley
Miembro Desde 03/01/17
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G2, Harley Spring 2017 Miembro de IUPUI, Team S1-G2, Harley Spring 2017
IUPUI-HARLEY-S17S1G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 170
