Saltar al contenido principal
BLU Dash 3.5 Camera Replacement
Qué necesitas
  1. BLU Dash 3.5 Camera Replacement, Battery: paso 1, imagen 1 de 3 BLU Dash 3.5 Camera Replacement, Battery: paso 1, imagen 2 de 3 BLU Dash 3.5 Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Camera Replacement: paso 2, imagen 1 de 2 BLU Dash 3.5 Camera Replacement: paso 2, imagen 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Camera Replacement, Camera: paso 3, imagen 1 de 3 BLU Dash 3.5 Camera Replacement, Camera: paso 3, imagen 2 de 3 BLU Dash 3.5 Camera Replacement, Camera: paso 3, imagen 3 de 3
    • Use the J000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Camera Replacement: paso 4, imagen 1 de 2 BLU Dash 3.5 Camera Replacement: paso 4, imagen 2 de 2
    • Locate camera module on inside of the black plastic back panel
    • Note the orientation of the camera.
    • Use tweezers to carefully remove the camera.
Conclusión
victoria dorony
Miembro Desde 09/28/15
22 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-2, Garvin Fall 2015 Miembro de Ohio State, Team 1-2, Garvin Fall 2015
OSU-GARVIN-F15S1G2
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 325
