Saltar al contenido principal
BEM Mojo 2 Speaker Battery Replacement
Qué necesitas
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: paso 1, imagen 1 de 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: paso 2, imagen 1 de 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: paso 4, imagen 1 de 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: paso 5, imagen 1 de 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
Conclusión
Rachel Iacoboni
Miembro Desde 01/30/18
618 Reputación
5 Guías creadas
Equipo
Baylor, Team S1-G1, Johnson Spring 2018 Miembro de Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 531
