Saltar al contenido principal
BEM Mojo 2 Charging Base Battery Replacement
Qué necesitas
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: paso 1, imagen 1 de 1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Battery Replacement: paso 2, imagen 1 de 1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Battery Replacement: paso 3, imagen 1 de 2 BEM Mojo 2 Charging Base Battery Replacement: paso 3, imagen 2 de 2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Battery Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
Conclusión
Rachel Iacoboni
Miembro Desde 01/30/18
618 Reputación
5 Guías creadas
Equipo
Baylor, Team S1-G1, Johnson Spring 2018 Miembro de Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 401
