Saltar al contenido principal
B-Flat Clarinet Key Pad Replacement
Qué necesitas
  1. B-Flat Clarinet Key Pad Replacement, Key Pad: paso 1, imagen 1 de 1
    • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
    • If the pad is missing completely, skip to step 3.
  2. B-Flat Clarinet Key Pad Replacement: paso 2, imagen 1 de 1
    • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
  3. B-Flat Clarinet Key Pad Replacement: paso 3, imagen 1 de 1
    • Squeeze a dot of super glue into the empty key.
    • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
  4. B-Flat Clarinet Key Pad Replacement: paso 4, imagen 1 de 1
    • Quickly insert the new pad into the key, taking care not to smear the glue.
  5. B-Flat Clarinet Key Pad Replacement: paso 5, imagen 1 de 1
    • Using the screwdriver, press the pad down to secure it to the key
    • Hold the pad for 5 seconds to let the glue harden
  6. B-Flat Clarinet Key Pad Replacement: paso 6, imagen 1 de 1
    • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
    • Let the instrument sit out for a few minutes to let the glue fully dry
Linea de Meta
Rachel Strobel
Miembro Desde 10/04/17
101 Reputación
1 Guía escrita
Equipo
Un comentario
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 1,317
