Saltar al contenido principal
Azpen A909 Microphone Replacement
Qué necesitas
  1. Azpen A909 Microphone Replacement, Back Cover: paso 1, imagen 1 de 1
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Microphone Replacement: paso 2, imagen 1 de 1
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Microphone Replacement: paso 3, imagen 1 de 1
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
  4. Azpen A909 Microphone Replacement, Microphone: paso 4, imagen 1 de 1
    • If you have never soldered before, there are guides on the internet and even on iFixit that make it easy to learn. We suggest becoming familiar with soldering before proceeding.
    • Now we are ready to begin the soldering process. You'll need a soldering iron, solder, and desoldering wick.
    • Clean the soldering iron by melting a small amount of solder onto the soldering iron's tip. Then wiping the tip of the soldering iron on a damp sponge.
  5. Azpen A909 Microphone Replacement: paso 5, imagen 1 de 1
    • If you are new to soldering, it is recommended that you check out iFixit's guide to soldering and desoldering.
    • Place the desoldering wick on top of the existing solder ball.
    • Hold the soldering iron in place until the solder melts into the wick.
    • Repeat the same procedure on the remaining connector.
    • Pull the desoldered wires off of the circuit board. They should come off with little to no resistance. If they do not come off easily, remove more solder from the contact points with the wick.
  6. Azpen A909 Microphone Replacement: paso 6, imagen 1 de 1
    • Grip the wires and slowly pull the microphone out of its mounting point. Some force may be needed.
Conclusión
Jordan
Miembro Desde 03/15/15
381 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-5, Duarte Spring 2015 Miembro de UMass Dartmouth, Team 3-5, Duarte Spring 2015
UMASSD-DUARTE-S15S3G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 156
