Saltar al contenido principal
Azpen A740 Speaker Replacement
Qué necesitas
  1. Azpen A740 Speaker Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Speaker Replacement, Speaker: paso 2, imagen 1 de 2 Azpen A740 Speaker Replacement, Speaker: paso 2, imagen 2 de 2
    • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
  3. Azpen A740 Speaker Replacement: paso 3, imagen 1 de 2 Azpen A740 Speaker Replacement: paso 3, imagen 2 de 2
    • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: Cómo soldar y desoldar conexiones
    • After switching out the old speaker, just follow the directions in reverse to finish.
Conclusión
Mallory
Miembro Desde 01/21/15
346 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 4-5, Brown Winter 2015 Miembro de USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 115
