Saltar al contenido principal
Azpen A740 Battery Replacement
Qué necesitas
  1. Azpen A740 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: paso 2, imagen 1 de 2 Azpen A740 Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: paso 3, imagen 1 de 1
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: paso 4, imagen 1 de 2 Azpen A740 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
Conclusión
Maile Sinclair
Miembro Desde 01/21/15
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 4-5, Brown Winter 2015 Miembro de USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,618
