Saltar al contenido principal
Azpen A720 Speaker Replacement
Qué necesitas
  1. Azpen A720 Speaker Replacement, Back Cover: paso 1, imagen 1 de 2 Azpen A720 Speaker Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: paso 2, imagen 1 de 3 Azpen A720 Speaker Replacement: paso 2, imagen 2 de 3 Azpen A720 Speaker Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: paso 5, imagen 1 de 1
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the speaker from the tablet.
Conclusión
Anna
Miembro Desde 03/17/15
353 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 244
