Introducción
The speaker is responsible for all non-headphone sounds from your tablet. If these sounds are not audible when they should be you may need to replace the speaker. Speaker replacement is a relatively easy task and this guide will help you through it.
Qué necesitas
Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
Casi Terminas!
Conclusión
