Saltar al contenido principal
Azpen A701 Motherboard Replacement
Qué necesitas
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: paso 1, imagen 1 de 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: paso 2, imagen 1 de 2 Azpen A701 Motherboard Replacement: paso 2, imagen 2 de 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: paso 4, imagen 1 de 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Azpen A701 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Azpen A701 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: paso 6, imagen 1 de 3 Azpen A701 Motherboard Replacement: paso 6, imagen 2 de 3 Azpen A701 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: paso 7, imagen 1 de 1
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: paso 11, imagen 1 de 1
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: paso 12, imagen 1 de 1
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
Conclusión
Michael
Miembro Desde 03/11/15
568 Reputación
4 Guías creadas
Equipo
Colorado Springs, Team 2-1, Panko Spring 2015 Miembro de Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
Miembros de 3
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 346
