Saltar al contenido principal
Azpen A701 General Disassembly Prerequisite Guide Replacement
Qué necesitas
  1. Azpen A701 General Disassembly Prerequisite Guide Replacement, General Disassembly Prerequisite Guide: paso 1, imagen 1 de 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 General Disassembly Prerequisite Guide Replacement: paso 2, imagen 1 de 2 Azpen A701 General Disassembly Prerequisite Guide Replacement: paso 2, imagen 2 de 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 General Disassembly Prerequisite Guide Replacement: paso 3, imagen 1 de 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 General Disassembly Prerequisite Guide Replacement: paso 4, imagen 1 de 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
Conclusión
Una persona más ha completado esta guía.
Michael
Miembro Desde 03/11/15
568 Reputación
4 Guías creadas
Equipo
Colorado Springs, Team 2-1, Panko Spring 2015 Miembro de Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
Miembros de 3
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 394
