Introducción
The charger port is located on the motherboard (the blue L-shaped piece) at the bottom of the device. In order to replace the port, a soldering kit is needed. Be sure you have all the necessary tools and safety equipment on hand before starting.
A guide to soldering can be found on iFixit's website here.
Qué necesitas
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
The charger port is located on the underside of the motherboard (as pictured).
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
