Saltar al contenido principal
Azpen A701 Charger Port Replacement
Qué necesitas
  1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: paso 1, imagen 1 de 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Charger Port  Replacement: paso 2, imagen 1 de 2 Azpen A701 Charger Port  Replacement: paso 2, imagen 2 de 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Charger Port  Replacement: paso 3, imagen 1 de 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Charger Port  Replacement: paso 4, imagen 1 de 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Charger Port  Replacement, Charger Port: paso 5, imagen 1 de 1
    • The charger port is located on the underside of the motherboard (as pictured).
  6. Azpen A701 Charger Port  Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the charger port by using tweezers and gently pulling.
  7. Azpen A701 Charger Port  Replacement: paso 7, imagen 1 de 1
    • Solder and place new charger port.
Conclusión
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Michael
Miembro Desde 03/11/15
568 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 606
